Thanks. Those are the updated rocker. That’s a bummer because it doesn’t look like they increased the nominal ratio at all.
Im glad I didn’t buy a new set to end up with the same problem of the nominal ratio being too low.
Chit. Look at a big block Chevy. LOLLol, next You get to find & try a W2 setup,...non-linear in 2 planes by quite a bit ...
Just get some Norris rockers and you'll be good to go.Thanks. Those are the updated rocker. That’s a bummer because it doesn’t look like they increased the nominal ratio at all.
Just a quick look @their site doesn't show those or any bushed ones. Must have to dig further to find them.
In the description they mention both needle roller bearings and bushings. So with a bushed fulcrum there’s only one other place a needle roller bearing could be.https://www.prwpower.com/prw-mopar-elite-series-shaft-rocker-system-3231812/p3120
I seriously doubt the roller tip is bushed.
Yeah but you'd have some actual good rockers. Last word was he was still making them out of his home garage.lol yeah, I’d have better luck finding a needle in a haystack than those
I think that's just a generic description. I can't see any bearings in the roller tip.In the description they mention both needle roller bearings and bushings. So with a bushed fulcrum there’s only one other place a needle roller bearing could be.
Only one way to find out.I think that's just a generic description. I can't see any bearings in the roller tip.
The ratio of on the old rockers might still be even less than these.Thanks. Those are the updated rocker. That’s a bummer because it doesn’t look like they increased the nominal ratio at all.
So, you think that 3 degree difference from 45 makes an appreciable difference? Comparing those 3 degrees to the 14 degree difference from 59 to 45, I can't see it. Especially if they run as well as they do with the 59 degree lifter bores. Evidently, it just doesn't matter "that much". I've sure seen that angle subtract a bit from the gross valve lift, though.I don't see how the SBM runs as well as it does with that misalignment, especially at high RPM. R blocks and Ritter blocks have the lifter bores at 48 degrees which is perfect. A line drawn through the cam centerline and the rocker adjuster cup is a 48 degree line. The 59 degree lifter angle was a hold-over from the 318 poly block. I guess Chrysler didn't have enough money or time to get it right.
Sinking the adjuster into the rocker body increases the rocker ratio. Extending the adjuster toward the lifter decreases the ratio. I’m not saying it’s a proper strategy, just sayin’.The ratio of on the old rockers might still be even less than these.
How much have you seen springs change the RR? Is it mostly rocker deflection?I have to look at my notes but IIRC they were 1.63-1.64 unloaded. EarlyA is doing his tests with checking springs they didn’t do much with the ratio.
I’m not sure I understand the reference to 45 degrees. 48 degrees is perfection for the SBM lifter angle. Factory stuff was 59. That’s the comparison I see.So, you think that 3 degree difference from 45 makes an appreciable difference? Comparing those 3 degrees to the 14 degree difference from 59 to 45, I can't see it. Especially if they run as well as they do with the 59 degree lifter bores. Evidently, it just doesn't matter "that much". I've sure seen that angle subtract a bit from the gross valve lift, though.
Some of the losses are shown in the two drawings. 0.430” of cam lift results in 0.415” or 0.419” at the other end of the pushrod.I'll bet the prod angle on the LA engines is a leftover from the Poly blocks which had different valve angles & positions. Any angularity will result in a slight amount of lost lift & motion, too little to worry about.
Any non-rotating needle bearings are bound to fail, due to back & forth motion & concentrated pressure. Rotating needles last a lot longer, like some later model rear axle bearings, which use larger 'Needles', but the same concept.https://www.prwpower.com/prw-mopar-elite-series-shaft-rocker-system-3231812/p3120
Good stuff. Thanks. It's amazing what forces and loads are present in a screaming engine.This graph and chart is interesting when thinking about the forces in play, when they occur, where they come from and how they are affected by rpm.
I wonder if the difference between the old and new design is just an increase in ratio and or something else.Sinking the adjuster into the rocker body increases the rocker ratio. Extending the adjuster toward the lifter decreases the ratio. I’m not saying it’s a proper strategy, just sayin’.
If I remember correctly @Newbomb Turk said there was a change in the bushing. Perhaps the old style had a split bushing (two halves) where the new one is a single bushing with a groove? All of that is in a thread here somewhere.I wonder if the difference between the old and new design is just an increase in ratio and or something else.
