[WANTED] 904 part throttle kick down valve body...
I have a bunch of 904 transmissions standing up . Most are 71's , I think there is 8 of them . I am an hour north. You can come pull some pans and look. Take a whole trans for $75. You can take them all in a bundle deal. They are all on pallets and I can get them out with a fork lift if you call in advance.
i saw them when i was there. still interested in them.. i think part throttle valve body was 73 up.. not sure thought..
its specific years i think.. not sure what year mine is.. its the smaller rear seal so pre 73 i believe.
The kit works on earlier transmissions as an add on to your existing valve body similar to the factory kit for certain years. Ill see if I can find it.
it says 66-69 transmission. not sure what year mine is. maybe I'll call them.
The transmission should have numbers stamped on a flat above the oil pan. You can tell the year from that number without pulling the pan. I'd also get a 4.0 kickdown lever, adjust the bands, and pressure while you are in there.
ok. best pics i can get of the numbers of the 904 in the car. only numbers i can see.
here is one of my spare transactions. thought i was told it was from a 69 coronet but not 100% sure. the valve bodies interchange correct ?
