abodyjoe
After around 65-66 they are all pretty much the same VB, but some got the PTK and some didn't.
The entire PTK kit is an add on valve assy, so when you pull the VB down it's pretty obvious if it has it or not.
Nothing about the PTK kit involves splitting the valve body or messing with check balls.
Is this what you wanted to know?
In the pic below the PTK valve section goes where those springs and valve are sticking out and it is laying on top of the VB in the upper left of the pic.
VB's without it have a flat plate there over those springs and valve.
old thread i know. i googled part throttle kickdown and this thread popped up. so all I'll need it do is pit that piece on my valve body to have part throttle kickdown?
part throttle kickdown i assume works like it sounds?
is there a vendor that sells the parts i need because the local yards don't have much old stuff anymore and it would be hard to find.
