You can see it and I posted an example.You have no idea doing sweep tests if the engine wants the whole curve moved up or down or parts of the curve moved up or down.
A person might get by with that but it certainly doesn't leave any cushion. I tell my customers " the least amount of timing that doesn't lose significant power"It’s about finding MBT, which is Minimum spark advance for Best Torque. It’s like guys want to use the maximum timing they can, even if it doesn’t make more power.
The cars that are that bad are not likely to be off by 1-3% on their timing for maximum performance. Maybe somewhere else in their tune.90% of the nasty driving junk cars out there are that way because the tuning is wrong. But you can’t say something or someone is wrong because hate.
