CudaRay
Active Member
I have a 318 that I was going to overhaul, but after washing up the block, I noticed these cracks. The cylinders are good, the only cracking is between the bolt holes and coolant passages. This car will likely see about 2500mi per year, and will make roughly 300hp.
I imagine this is probably junk, but I'd have to double my budget to remedy this with a new block near me. I'm not sure if it's good to send it with just a reduced lifespan, or maybe repairable. I did see this engine running before it was pulled from a d150, so who knows. The cracks are at the centerpoints of the passages, its all 4 of the upper bolt holes.
Is this a common thing with 318s or la small blocks in general? Has anyone ran an engine with this kind of damage?
