I did not make that up. Its still on BFGs website. The sites format has been changed so it looks different.
Oh, I believe you. Just sounds like some real psychobabble on their part.I did not make that up. Its still on BFGs website. The sites format has been changed so it looks different.
Tire FAQ - Got tire questions? Get answers now. | BFGoodrich USA
7th category
9th item down
I also recall seeing that UV light will diminish the browning effect.
The Goodyears I recently took off are 50 years old and are still white, as is the Tiger Paw that resides in the trunk for over 50 years. The fact that BFG hasn't rectified this issue in Forever is shameful at best.My 35 year old Goodyear Polyglas I took off the Bird are still WHITE ! The new ones I bought this Spring are bright white. The new T/A's on the Wife's Formula S are BROWN, as are every other set of BF's in the house. I'd never buy them, they just happened to come on the vehicles we bought. The Cooper Cobra's (made by Goodyear) on my 64 are 5 or 6 years old and are WHITE...
My highschool buddy had a Monte Carlo with BF's on it back in '78. They turned Brown a few weeks after he cleaned the Blue coating off... tire marker after that! Nothing has changed in almost 50 years.. The Goodyears I recently took off are 50 years old and are still white, as is the Tiger Paw that reside in the trunk for over 50 years. The fact that BFG hasn't rectified this issue in Forever is shameful at best.
They have rectified it... they say its not a problem, so the problem doesn't exist!The fact that BFG hasn't rectified this issue in Forever is shameful at best.
My 7 year old BFG's do not.They have rectified it... they say its not a problem, so the problem doesn't exist!
My 7 year old Cooper Cobras white letters clean up with any of the OTC tire washes.
I scrubbed them both with 2 or 3 different products and methods.. I took a Scotchbrite pad on a die grinder to get the "TA" white again. The brown comes back in weeks.Mike - give the acetone a try and see what you think. Here's mine after that (car is in dark garage so the letters are actually whiter than they appear in this pic).My 7 year old BFG's do not.I scrubbed them both with 2 or 3 different products and methods.. I took a Scotchbrite pad on a die grinder to get the "TA" white again. The brown comes back in weeks.
Exactly!I wish I would have bought Cooper.
Like I mentioned in my post, I had dealer replace original set of tires after about 30 days because of white letters turning brown.
Second set of replacement tires are also turning brown.
I feel I shouldn't have to continually scrub the tires to keep letters white on $1000.00 tires that are a few months old!
I bought 14's and 15's at the same time. The 14's on the front never did turn brown, Noting but issues with the 255/60-15's on the rear. I tried many different whitewall tire cleaners. No good. I had to grind the letter surface to get them white and they would turn brown within a month.There was a spell about 4 years ago where this was terrible. The 205's we put on the Duster constantly turn brown in about 6 months. A few years earlier the ones on the Coronet never had a hint of brown. Since the Duster I have put them on 3 more restorations and so far they have not turned as brown as the Duster but they take some maintenance to keep them nice and white.
Mike - have you tried the acetone?I bought 14's and 15's at the same time. The 14's on the front never did turn brown, Noting but issues with the 255/60-15's on the rear. I tried many different whitewall tire cleaners. No good. I had to grind the letter surface to get them white and they would turn brown within a month.
Yes and it didn't work.Mike - have you tried the acetone?
Very interesting - 1st time I've heard of it not working. Something's going on differently with these tires!Yes and it didn't work.
When I spend too much time in the sun I don't get whiter, but red and sore!!!Take a wheel off and put it white letters up in direct sunlight for a couple days and then compare to ne that was not in direct sunlight and see if that makes a difference. I cant find it but I recall seeing an FAQ from BFG about UV turning the brown white again
might be a new issue for Cooper. my 7-8 year old Cobras get super white with typical tire cleanersMy Cooper cobras are doing the same thing, after a year old they started turning brown.
The old Cooper Cobras that were on my car when I bought it had turned a little brown. The tires were almost 10 years old but still in great shape and soft, didn't appear to have been driven much. I didn't attempt to get them white. Replaced with BFGs.My Cooper cobras are doing the same thing, after a year old they started turning brown.
