Kendog 170
Let the boy go !
Poster 13 isn't glue stays soft. I would check the drain holes and use the sealant
It looks like you may have the square holes there already, might be covered with lead or sealer? Attached a pic of my car for reference.I guess, I was lucky that my car apparently didn’t have a leak before I replaced the gasket!
I would think it would get rust in the channel just because the water sits there every time it gets wet, because it has no drain holes to let it out. I guess you would have to blow the channel out with air every time it gets wet to keep it from rusting.
My car was no beauty queen when I bought it, but it has very little rust. It must’ve been in a garage a lot even though it was pretty ugly. It’s been in the garage since I bought it in 2008.
I’m going to try to figure out exactly where to put a couple holes, I guess drilling would be OK.
I have a new gasket (Precision Parts WCR D759) and CRL7708 sealer on the way.
From what I have read, it sounds like the sealer should only go along the bottom. But I would think at least a little bit all the way around, leaving the holes open, couldn’t hurt. This car is only out in the rain if I get caught in it. Service manual doesn’t seem to be available for 1974. But, thinking about it, I guess any year with the same type of windshield installation would be good. I’ll look into it.
This stuff is excellent for window openings with rails or walls or the pinch welds where panels come together, whatever you want to call it.CRL7708 sealer
I can see a faint outline of the hole! You have great eyes!It looks like you may have the square holes there already, might be covered with lead or sealer? Attached a pic of my car for reference.
It sounds like your car and my '74 have the same body construction in the windshield area, but use a different gasket. My gasket has a round cord-like lock strip that gets pushed into the gasket, on the top and sides, after the glass is installed. Along the bottom is a flap that gets tucked into a groove in the gasket.This stuff is excellent for window openings with rails or walls or the pinch welds where panels come together, whatever you want to call it.
Gasket has a groove that slides on to the rail.
So, I went and opened my seal, WCR D690 for 68-72 A-body excluding Duster.
Exterior of gasket has a tongue and groove along the sides, and the top and bottom corners are completely open.
Any water that gets in will drain out the bottom corners.
The bottom of the gasket has a groove for the bottom rail between the cowl drain holes, separate from the rest of the gasket, last pic.
Problem is, there is no bottom raised rail on the car.
If water gets into the groove on the top/sides of the gasket, it appears the gasket directs that water to the cowl drain holes.
Why is there expectation that water will get into the groove on the top/sides of the seal, and therefore need to drain, but not into a useless bottom groove?
Why have a bottom groove that has no male counterpart?
Why design it so water can easily get under the bottom into that groove and have nowhere to drain?
With no sealant, it just looks like those drain holes could easily become overwhelmed.
I knew that at some point, it got pushed out and replaced with some useless information, must've exceeded storage capacity.the "fence"
I read that, too. Imagine how many people cursed at that after struggling.I knew that at some point, it got pushed out and replaced with some useless information, must've exceeded storage capacity.
I followed the fsm when installing the windshield in my 62 Dart, it states to install in the top first.
It was impossible, struggled for hours, gave up, tried it bottom first, 20 minutes later it was completely done, stainless on and everything.
Cars.
