Data Logging Menus: tunerstudio
Got it, yeah I saved it to the desktop. Its hard to upload stuff like this to hereThat doesn't seem like a valid file Matt.
Try to get a data log and a composite log file. Connect your laptop to the MS3, then select "Data Logging" -> "Start Data Logging" and take note of where it will write the log on your laptop.
Hopefully lol thank you for checking itLooks like the right file this time. I'll have a look when I get home.
I'll post up that one, I have that one saved tooUnfortunately all I'm seeing in that log is one page and it looks fine. It's not the same log posted earlier.
Just updated the firmware to 1.6 release after I did these logsThis isn't showing any real errors either - the only loss of sync appears to be after the engine is stopped. I'd recommend trying to run both a data log and a composite log at once. They don't interfere with each other, and each will show things the other doesn't.
Also, alpha code?!? I'd seriously consider switching to a stable release.
Oh dang it, that's odd since it right clicked on the datalog and clicked share. Okay let me try it againSorry, I'm seeing the same composite log posted twice.
