So, I bought this Crappy Project for a Winter Toy/3rd Vehicle. I got it running and attempted a Test-Drive. ('95 Cherokee w/270k miles)
ChittyChitty BangBang ClunkClunk Pop! Rear-End is about to Jump Out of this thing.
So up on Jackstands and have a Look and Listen Running, in Drive. Pop Pop Pop Pop Pop Pop on the Outside of the Axles.
I did Outer Wheel Bearings and Seals. A bunch of water came out when I removed the cover too!
Put it back together and... Same Noise, No Fix. Well, this 8 1/4" Chrysler needs some help. I bought a Full Kit. Ring and Pinion, Bearings, Spiders, All the goodies.
And Needless to say, after all of that work it Still sounds the same.
This Jeep has had one of the Rough Country 3 1/2" Lifts installed by the P.O. and I guess the Pinion Angle has been the Culprit all along.
(I didn't Think of that) So, now I'll try to Lower it a Bit in the Rear and Shim the Rear Leafs... maybe try to Lower the Transfer-Case some to get the Driveshaft a little more in-line?
It looks pretty bad in the Front.
Any Suggestions?
Any Suggestions?
