Did the machine shop sonic test the cylinder walls for thickness? .040 my be pushing it.
That's in the plan before proceeding. Bore measurements conveyed to me on the phone ranged from 4.071 to 4.075.Did the machine shop sonic test the cylinder walls for thickness? .040 my be pushing it.
Just so you know;That's in the plan before proceeding. Bore measurements conveyed to me on the phone ranged from 4.071 to 4.075.
Crain Cams were a block from my home in Hallandale, Florida, before they moved to Daytona. Several of my friends worked there and I was given Fireball cams for my 340's to play with. I tossed them when I moved five years ago. I run the DC Purple cams now, but wish I kept the Fireballs, for a rainy day. I didn't think the parts of today were so crappy made. These cams were from the 70's.I had a Crane Fireball in my 66 390 Fairlane with 3.89:1 when I was in High School. That S.O.B. would stripe the neighborhood at will... and it earned me a restricted driving license to boot...
If you have pistons in the 4.070 bore size, hone the block to 4.078 for all the holes.
Send your pistons to Line2Line coatings and have your pistons coated. They will end up running at .0015-.0020 clearance and they won’t stick or rock.
Last set of pistons I had coated were 320 plus shipping.
I’d rather run used, coated pistons than uncoated new pistons.
I'm curious your thoughts on the OP's proposed combo. Any concern about the 8.23:1 dynamic compression ratio with iron heads and a pretty wide quench distance (0.051") on pump gas?
I’m with Tim. Better to run a typical .038 head gasket for the quench then tune it up. Carb and distributor. Run the 91/93 octane and be good with it. It’s a good combo. Stab it with the cam for the rpm range you want to be in and let it rip. It’ll be just absolutely fine.I'm curious your thoughts on the OP's proposed combo. Any concern about the 8.23:1 dynamic compression ratio with iron heads and a pretty wide quench distance (0.051") on pump gas?
