Supporting engine with trans removed
I would cut a 2x4 the width of the inner fender and hang it from there. If you want to distribute the load better cut some 6 inch long pieces and put a towel down on the fender first then put the 2x4 on edge on them. Fit and screwed together before installation would be a good idea.
In my drawing the 2x4 is not on edge but it would be MUCH stronger on edge OR a 4x4. The back of the engine is probably 1/2 to 2/3 of the total weight of the engine so 200 to 300 lbs
I did that this summer and you're right, on edge or a 4x4 would have been better. The 2x4 sagged but held. I don't know what the little 4-banger and transaxle weighs. A rusty hooptie so I didn't use rags. :p
I'm a belt and braces guy when it comes to holding up an engine, so a block of wood, too.
I did the 2x4 thing, but reinforced with a section of 1/8 angle stock.
Also I attached a scissors jack to one side (block on the other) and that allowed lifting/lowering of rear of engine.
I usually take the distributor cap and rotor off and let it hang. Easier to take the top bolts from underneath and easier to install. If you have a shroud you may have to take those bolts out.
The jack from my 01 Dodge pickup works great for that task. + being a screw type jack no worries of it bleeding down and has a very small foot print.
I bought one of these (and I think it was on sale or I got some kine of deal) but it was well worth the money. It’s really heavy-duty and worked great on my 65 Dart convertible. Thought I had a picture of it in use but can’t find it.
Pulling trans, then pulling k-frame.
2x4 bracing screwed together, thick heavy iron bar from my parents 200+ year old barn.
Bar looks bent in first pic but it's not.
I supported it from below. A floor jack to lift it up, then jam some 4x4's under the oil pan, then gently set it down on the wood.
But I'm a retard, so don't do that.
