I need a 26" radiator for my new motor (460+hp) in a 73 Cuda and ran across a barely used Champion CC281B for a Chevy Impala application that is priced right. I will obviously need to figure out if it can be made to fit the opening, but I'm more worried about the cooling capacity and looking for feedback from experience with a similar model from Champion. Specs are below but short story is that it is advertised for up to 650hp and is a three row with .75" tubes. Is that 650hp rating reliable with a proper shroud and fan package? I thought I read a while back that 1" two rows were more efficient, but I can't find that reference any longer. Car will be used on the street a lot and road racing/Auto-x so cooling capacity is important.
3-Row Core | Cools up to 650hp
Radiator Dimensions:
Total: 21.25" tall (21.75" with cap) x 28" (with brackets) (27" Center)
Core: 16" tall x 24.5" wide x 2.5" thick
Inlet: 1.5" passenger side
Outlet: 1.75" passenger side
Tanks: 2.75" thick
Tubes: 0.75" thick
Bracket Mounted
13 lb. Radiator Cap included
Transmission Cooler included (1/2-20 Straight Thread, Inverted Flare)
Aluminum Shroud is also available (sold separately)
When using electric fans:
One 16" or two 12" Electric fans recommended for this core size (sold separately)
Description
Champion All Aluminum Radiator3-Row Core | Cools up to 650hp
Tanks: 2.75" thick
Tubes: 0.75" thick
Bracket Mounted
