Starter time
Ironmike
Western Pa
Time for a new starter for my smallblock stroker. Way back in the day I remember I bought a Dakota mini starter but I don't remember the year. Hope you guys can steer me the right way.
The following table shows the highlights of the early, and swap suitable, mini-starter production, followed by some notes:
Chrysler NumberProductionNippondenso NumberNew Changes & NotesLester Number
43791441988 - 1990128000-527Introduced in production on 239, 318, 360.17084
53005984, 53005984AB,
P5249644
1991 - 1995128000-781,
128000-7810
Improved design. Slightly shorter.
P5249644 is Mopar Performance.
17466
560277021996 - 1998228000-339Terminal revision.17573
56027702AB, 56027702AC1999 -2003228000-742Replaces 56027702. Also used on the 3.7L and 4.7L engines.17785
There are later production numbers and various application interchanges with aftermarket numbers which are typically based on the Lester numbers.
In general, a starter based on the 53005984, or Lester 17466, is the candidate for use on an earlier engine to replace a Chrysler gear reduction starter. Typical aftermarket Lester based numbering will look like 17466N, N17466, or similar. Lester number 17466 is generally specified to replace the following:
  • Chrysler gear reduction numbers: 2095150, 2098500, 2785560, 2875560, 3255250, 3656575, 3656650, 3675560, 3755250, 3755259, 3755900, 4091950, 4091975, 4106113, 4106114, 4111855, 4111860, 4145300, 4145359, 4145360
  • Chrysler direct drive numbers: 1877560, 4145568
  • Chrysler Denso numbers: 53005984, 53005984AB
Excerpt from Chrysler Gear Reduction Starters.
i always say dodge mini starter for a dakota and they seem to know what i'm looking for. i have high comprerssion at 16.4:1 and it works.
90 dodge w150 the starter came with the wire adapter for the starter end at autozone. Keeps the wires on the outside facing the correct way
Here's what I used on my '71 Dart GT 318/904
