Highly modified, but certainly still counts for a leaf spring suspension. Really impressive indeed.I do not know the specifics of the chassis design or wheel tubs. I do know it had caltrac monoleafs, assassin bars, and sliders.
Nice! What shocks were you running? And did you relocate the front spring eyelet up against the floor pan per the Mopar chassis manual.My old W5 Duster has been mid 9’s at 3200+ on a 28 by 10 Hoosier quick time pro with 002/003 Mopar leafs. Dinky tire, but why put heavier more expensive tires on. A 14 by 32 on a 9 or 10 second bracket car looks like poo..just my opinion.
And it printed slips. Most Mopars have great rear overhang and want to work well without rocket science.
To the OP, Cal tracks will easily get it done without tractor tires at that power level
Thanks, Im going to dig around and see what I can find on how they fit a big tire in there. I’ve heard that with any kind of leaf springs that you can’t move the frame rails in to much or at all as it effects the chassis and handling of the car as it launches and makes the car inconsistent. I read that some years back on another web site as I was dreaming about building my car. I don’t know if this is true or not.I do not know the specifics of the chassis design or wheel tubs. I do know it had caltrac monoleafs, assassin bars, and sliders.
Probably will be a Dana rear end. I just retired about a month and a half ago and I should’ve had this car finished already but it’s been setbacks after setbacks. I’m planning on being a serious racer for a few years then playing around at test and tunes. I’m planning on racing the March Meets and hot rod reunion every year until I grow tired of it or can’t afford it anymore. LOL!!!I am no guru but I wouldn't go anything less than a 4 link. You're going to need all you can get to hook up 700+ horsepower. What rear end are you running? It should be a Dana or 9", narrowed with a full tub. If not, good luck. Also, and I have to ask, are you a serious racer or are you just playing?
My car is set up with sliders and split mono from caltracs, 29.5 11.5 w 15 hoosiers
The engine should push a little more than 700 hp if I can quit changing stuff and leave it together log
Did you mini tub it or put tub’s in it. Also what size rims and backspacing did you go with. ThanksMy car is set up with sliders and split mono from caltracs, 29.5 11.5 w 15 hoosiers
The engine should push a little more than 700 hp if I can quit changing stuff and leave it together lol
Does your car run the caltrac split mono leaf system. What ever you run can you give me the low down on tires, rims, rear end, mini tubed, suspension etc…….. I really like the stance and look of your car and that’s what I want mine to look like!!! ThanksYou will be fine with a caltrac split mono leaf system in your car
I have a narrowed Dana , I did major surgery with my back frame rails, I sectioned the entire trunk to rear floor pan & narrowed the frame rails, for tubs I'm still in the process of making them, it's just going to be sheet steel.Did you mini tub it or put tub’s in it. Also what size rims and backspacing did you go with. Thanks
Used CE 3 ways at all 4 corners. Springs were in stock location, just used solid aluminum eye bushings. Crude but very effective.Nice! What shocks were you running? And did you relocate the front spring eyelet up against the floor pan per the Mopar chassis manual.
Appreciated, I have CE's all the way around on my 69. I will have to spinn up some bushings!Used CE 3 ways at all 4 corners. Springs were in stock location, just used solid aluminum eye bushings. Crude but very effective.
There are guys running 2000+ hp on leaf springs with caltracs. And they can make em hook on a dirt road with a 28x10.5 radial.
At one point Lyle Barnett drove Jason Digbys dart to the fastest leaf spring car record.
Cause I love the big tire.Dinky tire, but why put heavier more expensive tires on. A 14 by 32 on a 9 or 10 second bracket car looks like poo..just my opinion.
Similar setup as Krusty. I have a 10.5X29.5 tire and Afco DA shocks. It works great, so far...My car is set up with sliders and split mono from caltracs, 29.5 11.5 w 15 hoosiers
Looks great.Similar setup as Krusty. I have a 10.5X29.5 tire and Afco DA shocks. It works great, so far...
I'm sure everyone knows set backs lol.Probably will be a Dana rear end. I just retired about a month and a half ago and I should’ve had this car finished already but it’s been setbacks after setbacks. I’m planning on being a serious racer for a few years then playing around at test and tunes. I’m planning on racing the March Meets and hot rod reunion every year until I grow tired of it or can’t afford it anymore. LOL!!!
Sorry, I was out of town racing all weekend and just got back on here. My car is a back half car with 4 link. Fully tubbed, old school 4 link from the 80s. Not much adjustment. 32x13.5W slicks, dana 60 narrowed, 4.56 gears, strange axles, wilwood brakes. Front half of the car is an AJE front suspension, rack and pinion, no torsion bars, upper and lower tubular a-arms.Does your car run the caltrac split mono leaf system. What ever you run can you give me the low down on tires, rims, rear end, mini tubed, suspension etc…….. I really like the stance and look of your car and that’s what I want mine to look like!!! Thanks
What size rim and backspace did you use. Did you mini tub it and move the springs to the frame rails to get the 10.5x29.5 tire to fit. Sick launch by the way!!!Similar setup as Krusty. I have a 10.5X29.5 tire and Afco DA shocks. It works great, so far...
Thanks for the advice much appreciated.If it hasn't already been said, great double adjustable shocks are important at your power level. If possible, pick shocks that can he used with what you have now, and also be able to move to a different suspension system.
What a lot of guys don't see is the tremendous torque applied to the rear housing at the hit. If you have 700 ft lbs at the crank,, it is 1400 coming out if the converter, times the total gear ratio.a 1.45 low x 4.56 gears is 11.17 times that 1400, or approximately 15,000 ft lbs trying to twist that housing, and the shocks have to control it . With a 20 inch front segment on leaf springs, I takes a lot of shock to slow it down enough . So a call to the tech people to discuss your true needs is important. It might save you from changing to better shocks four times before getting it right like i did
Thanks, I have a lot to mull over between a four link or mono leaf. But the true deciding factor is price and with the set backs I’ve had with this car this last year is probably why I’ll go the cheapest route and hopefully go four link at a later date.Sorry, I was out of town racing all weekend and just got back on here. My car is a back half car with 4 link. Fully tubbed, old school 4 link from the 80s. Not much adjustment. 32x13.5W slicks, dana 60 narrowed, 4.56 gears, strange axles, wilwood brakes. Front half of the car is an AJE front suspension, rack and pinion, no torsion bars, upper and lower tubular a-arms.
Now my dad's roadrunner has a split mono leaf spring with a ladder bar and housing floater. So does my friends roadrunner. Close friend of mine runs a true caltrac split mono leaf with the caltrac bar setup. His car has been 5.72 at 119MPH at 3385LBS. My dad's setup has adjustable ride height which was nice that he had it built that way in the 80s.
I think you will spend substantial amount less time messing with a true caltrac setup than messing with a 4 link. Although the 4 link is the ultimate in adjustability, theyre a pain in the *** to get dialed in. And if you put a 4 link in with no anti roll bar, they become much more challenging to handle. Just my opinion and what I have gone through. My car being a very old 4 link car, leaves a lot higher than you would want a 4 link car to leave. But due to my lack of adjustability since the suspension is so old with not many holes for adjustment and big space between the holes, I just found something that I know I can make work and stuck with it.Thanks, I have a lot to mull over between a four link or mono leaf. But the true deciding factor is price and with the set backs I’ve had with this car this last year is probably why I’ll go the cheapest route and hopefully go four link at a later date.
