71DusterStruck
Looks great, you are doing a very good job!
Man, You are sooo lucky to have an "old man" to help you out! It looks freeking awsome! You really turned that old "turd" as you called it into something really bad azz. Its going to be a show stopper when you get done!
Keep up the good work!
Looks really good.It's been a while since I've updated this board. The front clip is done and slides on/off real easy. I'm in the process of mounting the engine and trans. Here are some update pics. Keep in mine the engine needs to move up about 3". In order to do that, I'm going to have to cut some of the floor out for the trans to clear.
Looks really good.
Did you run the bars through the firewall to the cage or just to the firewall?
Are you going to use a stock type front suspension?
Do you still have the dash vents?
Here's what I did with my K member
I'm still up in the air on the front suspension.
Its looking great. The front end work and clip is similar to what my Dad did to his 69 'Cuda:It's been a while since I've updated this board. The front clip is done and slides on/off real easy. I'm in the process of mounting the engine and trans. Here are some update pics. Keep in mine the engine needs to move up about 3". In order to do that, I'm going to have to cut some of the floor out for the trans to clear.
