homecloned
Can't re Member
I took a tip from challangergary and tried the Rustoleum satin black paint at the cost of $9.00 for the Qt. I am more then satisfied with the results.
I'm not sure how much thinner I cut it with because I was adjusting it as I sprayed but it's around 35%.
I was just going to surface repair them but they had some ruff spots so I just stripped them down with stripper.
Does anybody know if these were all painted black and then changed at the factory if orderd with body color? The reason I ask is under the top coat was the same color as my GTX, dark green met. which definitally looks like factory paint, and under that was the flat black.
I primed with rustoleum automotive spray bomb primer but forgot to take a pic of that stage.
When I started spraying, it was a little thick and I adjusted the mix, had a couple of light coat's on and readjusted one of the scoops on it's table and ended up blowing some dirt into it.#-o No biggie, I let it dry for a day, wet sanded with some 600 and sprayed 3 more coats on.
I need to wax them once there cured. They have been sitting in the garage while I have been sanding so what you see in the pick is just residue from what I wipped off.
I will paint the wing and rocker panels with this as well.
Also if somebody can inform me on the correct mounting screws it would be much appreciated. These are the four that were in mine.:dontknow: The bezel has a tapered hole like an interior screw but larger.
Thanks for looking.
I am sarting
Thanks for looking.
I am sarting
