waggin
moving on ain't easy if you drive a Ford :p
Here ya go
well i just got home from wetsanding....My paw's are killin me and i think i dun sanded off all my fingerprints
When I get my car prepped for paint, You want to paint it for me????? Your car looks AWESOME!!!!!!
Dam wags that thing looks good the way it is..:cheers:
Your doing the wet sanding the hard way. Use the D/A with a foam backing pad.
we D/A them with 1000 dry, Then hit it with 3000 wet. It will shine before you even buff it. It does come out flatter with a block though
http://www.eastwood.com/6in-soft-foam-interface-pad.html
Wet sanding with a pair of paint paddles was the way I always dun it waggin.
I remember my finger tips trying to separate from my nails :angry7:
Yep spay pottle with warm water to keep the sand paper clean and surface wash back is the way to go :cheers: I use a new bondo spreader to keep an eye on my work as I go.8)
Nice job waggin =P~=P~
waggin, what's the paint code? looks like ruby for 64 or 65, I think they changed the name red poly metallic or something... looks awesome!
