Mad Dart
Nothing to see Here!
Ok, I have lined up all the pin holes at the bottom of the shifter and ALL the rods have been put on correct with trans in neutral. The issue I am having is that when I go into Reverse and then try and go to neutral to grab 1st gear it binds up. With some serious wiggling and kind of Pulling up on the shifter it will eventually go. Does this sound like the shifter itself is out of adjustment??
If so can someone give me direction on how to do it?? I can see an adjusting bolt on the front of the shifter. What exactly does it do before I mess with it?
And is there a procedure to follow when adjusting it like the above with the pin holes and trans being in neutral??
HELP........ SHOULD I BUY ANOTHER SHIFTER?? THE TRANS SHIFTS FINE AND ALL GEARS WORK CORRECTLY!
