bjkadron
OK, what is everyone's ride height? how far is the lower control arm bump stop from the frame, and how far is the middle of the K-frame from the ground? what is the average/normal ride height?
Reilly is telling me that:
"1.0 inch torsion bars are WAY too stiff for a small block car and that with a ride height that high, geometry sucks. It will still wander all over the place, and since those bars are totally unwound at ride height, the ride quality will be miserable."
So, now I have the ride height down, and the LCA bump stops are just touching the frame...The torsion bar adjuster bolts are almost all the way out...Is it possible I installed the torsion bars wrong? can I clock them a different way? does it matter?
I would say mine Duster is about 7" from the k-from to the ground. I have about 3" below the swaybar mounts. Which is too low for the stock bars so I need to crank them up even more... They are to where I can't turn them with a wrench just a socket now. I can't measure at my house because their is nowhere flat, but I can measure for you on Wednesday.
