help me pick my nitrous kit!
mopardart72
I'm a pretty big deal
Laquey missouri
First off is a edelbrock concielded nitrous kit with a 10 oz bottle gives 30-60 HP and costs 256$
http://www.summitracing.com/parts/EDL-70027/
next is Nos sniper kits, Nitrous Oxide System, Sniper, Wet, 100-150 hp, 10 lb. Bottle, Orange, Square Bore, 4-Barrel, Kit . 389$
http://www.summitracing.com/parts/NOS-07001NOS/
Nitrous express Nitrous Oxide System, Hitman, Wet, 100-200 hp, 10 lb. Bottle, White, Square Bore, 4-Barrel, Kit 432.00$
http://www.summitracing.com/parts/NEX-40040-10/
And last but not least the old sneaky pete system from NOS,
Nitrous Oxide System, Sneeky Pete, Dry, 50 hp, 10 oz. Bottle, Natural, Carburetor, Kit 247.00$
http://www.summitracing.com/parts/NOS-05029NOS/
so what do you guys think. my dart is a mild 318 with just an intake headers and a mean *** cam the carb is a old carter car for now. all stock innards but the cam
#2 or #3. Don't bother with the other 2 because you will only see that 30-60 or 50hp gain if the sun is out, your hair is combed right and the dog taking a dump in the neighbors yard is facing east.
which end of the dog is facing east?:-D
with the wet systems you dont need to change the jets in your carb because the system uses additional fuel via a solenoid. you need to make sure your pump can handle continuous 5.5 to 6.5 psi. i run a 50 shot on a similarly built 360 and i actually got 80 hp and 85 tq from it on the dyno. i run and edelbrock kit and thats what i would recommend.
