72BBSwinger
I have 11/16" Energy bump stops and I am about 1/2" from them at ride height.
So I see a lot of I got this and I got that.
What is the correct answer?
Is there a correct way to set this adjustment
or a factory ride height chart or spec?
http://student.ccbcmd.edu/~smacadof/Books/A4_SuspSteer_Student Work Books/SWB_a4_m04b_Final.pdf
http://www.carcraft.com/techarticles/ccrp_0910_diy_alignment_guide/viewall.html
Actually the factory ride height ignores tire size. It is completely irrelevant to the measurement. I don't use the factory method because it's a PITA. I just measure from the LCA to the frame, get that inch (approximately) between the bumper and frame, and then make sure both sides are the same.
Ding ding ding ding ding! Finally somebody gave correct information! Drop spindles is the ONLY correct way to drop your front end!Tires do make a difference in the way a car handles,
but if the suspension is not setup properly travel wise
you can forget any kind of performance handling.
If your on the bump stops whats the point in
shocks or swaybars not to mention any alignment gains.
All your doing is bashing the a-arms and stressing
the steering components.
You might run drop spindles to lower the car without
compromising handling.
Ding ding ding ding....
You're wrong.
Lots of other parts, intentions, and use of the vehicle change what's right and wrong. Lots of different ways to get to the same place. And we are modifiing cars. Is there only ONE right camshaft, carb, header, etc for everyone?
And the drop 2" spindle changes the front roll center.
How were the condition of the front shocks when you got it? Original front torsion bars?
My car is at factory ride height on this pic. How much lower would you want to go.
Just enough to make it look cool and handle better..? :happy1:
