65-440
Alright, went to start my dart up this afternoon and what do you know ....... NO START !! ahh ****, this car has never failed me before. It has sat for a little over a month, first thing I checked was fuel. Plenty of that stuff .... Put my spark tester on Cyl #1, and no spark. Checked ign voltage at the ballast, then to coil .. that's was good. Inside of cap appeared good, rotor turned when cranking. Found battery voltage on the - side of the coil coming from the ECU. Swapped the orange box out for my el cheapo spare, fired right up. So pissed, I bought that box maybe a year ago. Considering other ignition options, maybe the FBO setup. Not adding a MSD box, I do know that !
