Is the date coded filter a 3/8" filter? I always assumed the majority of the stock type filters were 5/16" The Edelbrock is similar to a stock 4 barrel Carter (AFB), so if you don't want to bend your own line, you should be able to get a stock style line from one of the restoration places (Classic, Right Stuff, etc.), but those are usually 5/16".
With that 5/16-3/8 fitting from jegs, just make sure you get it exactly where you want it when you tighten it. If you have to loosen it, it will leak.
Why are you trying so hard to keep a date coded fuel filter, and then not pay attention to the proper stock size fuel line??? :violent1: :violent1: :violent1:
It's either stock, or it's not...
Morphing the fuel line is not stock, so what benefit are you going to get for a date coded fuel fliter and a non-stock fuel line??? #-o
