I got everything put back together and I got a nice louder jingle... I checked the front suspension and everything appears to be tight. Does this sound like anything maybe youve heard before?
To me it sounds like a nut/bolt or something metal is loose and bouncing around, but is it the rear end that is pinging? Is this what it sounds like? First video is shorter but sounds better, it happens at about 25mph until I start to slow down. I'll probably jack it up tomorrow and again double check to make sure all the nuts/bolts are tight.
