Jingle F***ing Bells...
DentalDart
Ozark Missouri
I got everything put back together and I got a nice louder jingle... I checked the front suspension and everything appears to be tight. Does this sound like anything maybe youve heard before?
To me it sounds like a nut/bolt or something metal is loose and bouncing around, but is it the rear end that is pinging? Is this what it sounds like? First video is shorter but sounds better, it happens at about 25mph until I start to slow down. I'll probably jack it up tomorrow and again double check to make sure all the nuts/bolts are tight.
We made it to pick up my son from school though!
Wont play. Need to load it onto youtube and post a link.
Seeing as you have been battling with the rear brakes, i would go there first.
Take off the caps and see if the sound goes away. Or if someone put some change in one ;)
Sway bars definitely tightened.
I think it could be this, which is for the original shifter linkages? It just kind of flops around not attached to anything and sounds a little like the rattling. Can I take it off somehow?
I loaded goigle drive just for you.
Sounds like hold down hardware is floating around.
There is a hex on the stud, could remove the whole thing.
Muffler clamp? Buddy of mine used to mess with people and put an extra clamp on for some customers....a loose one lol.
Could be the sequins on your red sneakers?
That's definitely a possibility too! I've been messing with the rubber hold downs/ clamps since I fixed the exhaust leak.
It sounds just like an exhaust loose clamp, donut gasket, etc. That's the sound they make right before coming apart.
Not the drums or the rear most exhaust clamps even though that one by the muffler sucks and doesn't hold the exhaust tight enough to the body.
I did have some amazing help though!
