my68barracuda
car is a 68 Barracuda
tires front 215/60/16 on 7 inch wide wheels
tires rear 225/60/16 on 8 inch wide wheels
the car is somewhat light weight, fiberglass hood and front bumper, aluminum front bumper brackets, light weight last year built slant. Carpet and interior trim is present, but no back seat, no under carpet sound deadening material.
The side wall of the tires says that max load capacity is at 51 psi.
Does a cold tire pressure on 38 psi seem about right?
The car rides and drives fine.
Thought I would ask to see what other folks run for tire pressure with non stock sized tires.
