.030 340 With KB Hyper Pistons, Ring Gap Info
Small Block Mopar Engine
  1. 340doc
    340doc Well-Known Member
    2,111
    553
    May 8, 2010
    Hollywood Fl
    Local Time:
    9:07 AM
    Ok, so I have a .030 over 340 going together. I'm used to using file fit rings. My question is for those who have used the KB Hyper pistons. How did your ring gap come in? Being that these pistons require a larger gap, did you have to file a standard .030 non file ring? According to KB's chart I need a .027 top ring gap. Thanks.
  2. brian6pac
    brian6pac Well-Known Member
    3,462
    1971
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    9:07 AM
    I don't like having such a big gap but hyper piston's require them. We built a 400 chevy and had a .028 gap and he overheated it and it scuffed the wall hard probably close to pulling the top off the piston. The piston is a lot smaller at the top putting more heat on the ring, that is why you need a big gap.
    • Agree Agree x 1
    • Wyrmrider
      Wyrmrider Well-Known Member
      1,139
      410
      Sep 5, 2016
      los angeles
      Local Time:
      6:07 AM
      yep ring is closer to the top and the hyper materiel does not suck the heat out of the ring
      you most likely can start with standard gap rings and file them
      but more important (IMHO) is to get a ductile or better top
      hyper gap when running is about the same as forged
    • moper
      moper FABO Gold Member FABO Gold Member
      15,489
      1586
      Dec 27, 2004
      eastern CT
      Local Time:
      2:07 PM
      I believe KB says .006" per inch of bore for naturally aspirated rather than the "usual" .004. More if it's going to be driven hard. So I'd go around .028 for the top, and probably .24 on the 2nd.
      • Thanks! Thanks! x 1
      • 340doc
        2,111
        553
        May 8, 2010
        Hollywood Fl
        Local Time:
        9:07 AM
        Yes .0065 per inch of bore. I'm going with a moly ring. I'm hoping someone chimes in and can let me know if they had to file a regular .030 ring to hit those numbers. Otherwise I'm searching for a .035 over ring.
      • nm9stheham
        nm9stheham Well-Known Member
        10,405
        2675
        Dec 20, 2013
        Waynesboro, VA
        Local Time:
        9:07 AM
        IIRC, yes we had to file the top KB moly rings that came with our .020" over KB 340 pistons. Piston-to-bore fit was set in the normal range fit for these pistons, nothing special.
      • 340doc
        2,111
        553
        May 8, 2010
        Hollywood Fl
        Local Time:
        9:07 AM
        Thanks, this is what I was hoping to find out. Do you remember what the second ring was at?
      • rumblefish360
        rumblefish360 so close yet so far away
        34,091
        6012
        Jun 21, 2005
        New York, on a Island
        Local Time:
        9:07 AM
        I’m file fitting my KB243 rings a little bit. Just a hair more than suggested.
      • nm9stheham
        10,405
        2675
        Dec 20, 2013
        Waynesboro, VA
        Local Time:
        9:07 AM
        Sorry, not off the top of my head... I won't be able to get to our notes for at least a week to see if I made notes on that. I don't recall touching them....
      • Wyrmrider
        1,139
        410
        Sep 5, 2016
        los angeles
        Local Time:
        6:07 AM
        easier to get ductile in .035 over
        just saying
        cheap insurance
      • PRH
        PRH Well-Known Member
        364
        441
        Dec 14, 2018
        So. Burlington, Vt
        Local Time:
        9:07 AM
        I never even try and run the ring gaps down at the min spec with the KB hyper pistons.
        I’ve used them a bunch of times, never any blow by issues.
        They’d be at .030 if I was doing it.
        .020-.022 for the second ring.
        • Agree Agree x 3
        • 340doc
          2,111
          553
          May 8, 2010
          Hollywood Fl
          Local Time:
          9:07 AM
          I agree but I'm having a hard time finding a file fit ring for a 4.070 bore. The KB's take the stock size 5/64 ring, not the more popular 1/16 ring. I started another post about that.
        • 340doc
          2,111
          553
          May 8, 2010
          Hollywood Fl
          Local Time:
          9:07 AM
          Are you able to get by without the .005 over ring then?
        • nm9stheham
          10,405
          2675
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          9:07 AM
          Cannot ANY ring can be a 'file to fit' ring LOL? Am I missing something here? Why not start with the standard KB rings for that piston in +.030? 4000AM8070 for moly top ring. (No ductile in that size in their catalog unfortunately.)
          If you go with a .035" ring a stuff it into a .030" bore dimensioned for a hyper, that is going to be tightening the ring gap.... and (I think) would be increasing the ring tension over what is necessary.
          • Agree Agree x 1
          • moper
            15,489
            1586
            Dec 27, 2004
            eastern CT
            Local Time:
            2:07 PM
            Because the usual gap the stock replacement rings come with is based on the factory spec - either ring will work. A plain "+.030" ring will not need to be filed as much.
            • Agree Agree x 2
            • Krooser
              Krooser Reform School Graduate
              996
              659
              Jul 19, 2015
              Land of Cheese
              Local Time:
              8:07 AM
              Better too big than too small
            • sireland67
              sireland67 Well-Known Member
              7,776
              1800
              Oct 27, 2010
              WV
              Local Time:
              9:07 AM
              You can file standard rings, just set them to the recommend gap.
              Make sure you have them a little more than KB recommends. Because your bore can have some taper.
            • MOPAROFFICIAL
              MOPAROFFICIAL Well-Known Member
              3,103
              2098
              Jun 1, 2016
              breakwater
              Local Time:
              6:07 AM
              .028 top ring
              .018-.020 2nd
              The top ring is spaced higher/away from the others...it gets the heat 95% .
              However...It wont hurt adding .004 to the 2nd ring, so do it it however you like.
              • 340doc
                2,111
                553
                May 8, 2010
                Hollywood Fl
                Local Time:
                9:07 AM
                That what I was wondering. I didn't want to buy a plain .030 ring set and find the gap too large. Standard ring gaps are usually large to make them error proof.
              • 340doc
                2,111
                553
                May 8, 2010
                Hollywood Fl
                Local Time:
                9:07 AM
                I know they can be filed, I just was worried about them coming in too big out of the box.
              • 340doc
                2,111
                553
                May 8, 2010
                Hollywood Fl
                Local Time:
                9:07 AM
                Yes any ring can be filed. Most standard ring sets have a built in larger gap to make them error proof in various situations. I didn't want to buy a standard .030 over set and find the gap too big out of the box
              • rumblefish360
                34,091
                6012
                Jun 21, 2005
                Local Time:
                9:07 AM
                Only for women, fish, lotto winnings and margin of victory.
                :lol:
              • nm9stheham
                10,405
                2675
                Dec 20, 2013
                Waynesboro, VA
                Local Time:
                9:07 AM
                Interesting... I can't say I have found that to be the case for fresh bores, properly sized. They always seem come pretty close to standard spec.
              • 340doc
                2,111
                553
                May 8, 2010
                Hollywood Fl
                Local Time:
                9:07 AM
                That's good to know. I'm gonna order the KB moly rings and hope for the best. Comments seem positive. Thanks to all!
              • MOPAROFFICIAL
                3,103
                2098
                Jun 1, 2016
                breakwater
                Local Time:
                6:07 AM
                Buy/use the ring sized for your bore, .030 over bore....030 over ring set, file fit them... there is plenty of room to open them up...the 2nd is usually just right or .002 tight.
                If I'm reading what I think im reading...Do not use standard size rings on a .030 bore!
                • Agree Agree x 1
