how much money you may spend i went .030 over plus the 408 stroker
Car has eddy heads, a 240 hyd flat tap cam i believe (dont have specs in front of me), eagle cast stroker crank, magnum rods, magnum block, ross pistons, eddy rpm intake, holley 650 carb, will be putting in msd all in one coil (so i dont have to run ignition box), 8qt sump, and probably more to list.
I will hopefully have the engine started within a month.
