BillGrissom
I am jumping back in after a long time, so forgive me if I missed something. You sound hung up on the voltage drop to the alternator field supply wire. Don't worry about that. What matters is the IGN1 voltage at Vreg. You might need to pierce the wire insulation to measure (there are sharp multimeter probes for that). Measure IGN1 relative to the case of Vreg (what it controls).15.5v across the battery posts due to a 1.5v drop at the alternator field plug (blue wire). ... I have increasingly large voltage drops as I move farther along the harness out towards the alternator and despite my best efforts (over a freaking year and a half time span), NOTHING has changed.
That drop should be ~14 V w/ engine running. If too low, Vreg commands "more alternator" by lowering the 2nd field connection (flows back to ground thru it). If too high, it commands "less alternator" (2nd field voltage increases). If doing that, Vreg is doing its job. If the battery is running higher, find the voltage drop(s) on either the supply or return side. You might have a 1.5 V drop from the Vreg case to BATT-, especially if relying on a rusty sheet-metal screw for that path (or a corroded frame to BATT- jumper). I ran a ground jumper to my Vreg, coated w/ silicone grease, and I am using the same later Vreg in my 1965 (triangle connector). I also have two direct BATT- to frame wires since I used battery wires from a Jeep GC, and designers learned to ground cars many places (some of our issues).
