1 wire internal or external oem alternator
oh, you'll have to make your own. probablt not hard since the stock bracket is so simple to start with.
Yes, I looked up that small block bracket that you posted that sixty five dollars, probably plus shipping, and it's the same triangle piece with a spacer and a elongated bottom bracket.And the bolts to fit...
You can see on mine.I just cut a spacer to fit up top and use my ninety nine.Dollar harbor freight welder, to weld together two pieces to make that curved bottom piece..
Again, my ninety nine dollar welder near paying for itself.Absolutely every time I use it... it's beyond my comprehension how ninety nine percent of the guys in this hobby?... Don't own one...
Yep. Gotta have a welder. I prefer my Miller mig. Point and shoot
I'd never recommend a stick welder.
It's crazy the amount of stuff I've been able to do with a $99 Harbor freight flux wire welder, $35 welding hood, $15 4 1/2 inch angle grinder with cutoff wheels, grinding wheels, and some flap disks for smoothing...
Untold amount of brackets and exhaust systems and frame connectors... I even built my own snowmobile sled deck...
ZERO FAILURES...
Im a better grinder then welder
Bought a tig cause my helpers like to weld
Once I get that set up they will teach my kid
Never learned tig
I have a 35 year old matco mig
Still welds but think im going to buy a new mig for the shop this year and bring that one home
