mopar65
Well looks like it might be time for me to sell my dart. so i will try to tell all about it the best i can.if there is anything you want to see or know about please just ask, ok here goes
I have a 1973 all steel dodge dart that was a factory 318 car.the car came from plant city FL.ok here are the engine info
1973 440 bored 0.030 over
wisco pro true flat top pistons
block has been decked
factory forged steel crank turned 0.010/0.010
stock main caps with ARP main studs
eagle rods, rotating assembly has been balanced
HV oil pump,moroso 8 QT oil pan, 1/2 hemmi pick up
mopar balck aluminum valve covers
Indy EZ cylinder heads, have been bowl ported,so posed to flow 310 at 600 lift
has indy plate that has removable center
TTI 2x3-1/2 headers
Comp Cams solid roller 0.0264 at 0.050 and 594 lift. installed at 104
crane 1.6 gold roller rockers
huges cams billet hold downs
billet 9 key way timing chain, not sure on brand
mopar aluminum water pump housing
summit/cvr electric water pump
summit 27.5x19 aluminum rad
tours electric fan
wieand tunnel ram
Holley 650dp with proform main body's, soposed to be 750dp now
wieand tunnel ram linkage
lokar throttle cable
Fire Core Dist and plug wires
Crane HI6R ing and LX92 coil
Fuel system
new holley black pump
summit 12 gallon fuel cell
Dash 8 fuel lines from cell to pump to carbs
Holley 4 port fuel pressure regulator
charging system
120am denso alt
01 battery cable
2 red top batteries
727 Trans mission built by me.
front pump mods etc
installed a race clutch rebuild kit i got from CRT
alto eagle red clutches/steels
solid red front/rear bands
billet front and rear servos
bolt in sprag
CRT RMVB with low band apply
4.2 apply lever with heavy duty band strut
dodge truck 48RE trans pan
B&M plate trans cooler
dash 6 trans cooler lines
B&M pro ratchet shifter
Stock dodge 7290 drive shaft that i had a 1350 end put on it, drive shaft balanced at drive line shop
Front suspension
73 disc brake set up
new rotors,pads
3 inch wheel studs
new poly lower control arm bushing
poly strut rod bushings
lower control arm bushings
the upper control arm bushing and ball joints were new when i got the car
factory 318 bars
Summit 90/10 shocks
weld 15x3.5 drag lite wheels
new 165R15 tires
rear suspension
mopar 002/003 super stock springs
springs have been moved in 3 inched per-side
dodge ram charger shocks on back
mopar pinion snubber
back braced 8-3/4
B-body 11x2 inch drum brakes
moser 30 spline spool
moser 30 spline axles with 5/8th wheel studs
742 case, richmond 4.30 gears all new doctor diff bearings etc
weld drag lite 15x8 wheels, 4.5 inch back spacing
M/T 275/60/15 drag redials, they need replaced
Ok the car is not a rust bucket but has some rust starting to show through on wear most abody do. like the very bottom of the rear 1/4 are starting to have some bubling etc. the hood scoop needs replaced, its cracked all over bad.i got it from JC whitney (cheep plastic)just so i could have something covering the tunnel ram.the car could use a repaint, the front and rear frames are solid etc.To make the car legal for the speed it has run it needs the following.
8 point roll bar
trans shiled
race seats
5 point harness which are out dated
the dart weighs 3520 with me in it and i have ran a best of 10.62 at 124.56 in the 1/4. i let my friend race the car that weighs about 110 pounds less than me and he ran a new best last fall of a 10.49 at 125 in the 1/4. i know there is more in this car becasue i have not got to really do any tuning on it ect. also all passes were made on 93 pump gas. the engine runs great and does not over heat. the engine has 80 psi cold and around 60 warm at a idle. have not seen the car get over 185 after making a pass in the heat. don't want to sell the car but want to pay some bills off. I am asking $7500 or best offer.I would be willing to meet somebody half way if they live fairly close. here are a few pics of the car. let me know if you want to see anything. but please to picture takers. thanks Bobby Miller
TTI 2x3-1/2 headers
tours electric fan
wieand tunnel ram
Fuel system
charging system
120am denso alt
01 battery cable
2 red top batteries
front pump mods etc
bolt in sprag
Front suspension
new rotors,pads
3 inch wheel studs
factory 318 bars
Summit 90/10 shocks
new 165R15 tires
rear suspension
back braced 8-3/4
8 point roll bar
trans shiled
race seats
