70DusterBob
Anyone know if anyone makes a 170 Thermostat for a 1975 360? LA
you really want it to run at 180-192 for best cylinder wear. Are you battling a cooling issue? I dont think a 170 will fix that. Whats the underlying issue?
Go to the source, thermostat manufacturers website.
170 is an odd number for SB what are you trying to accomplish
StantWhat do you mean "Go to the mfg's website"?
Get the 10 degree controller?
16759
Also do you control the 2 fans together? Maybe run 1 fan all the time and control the 2nd fan? It says this model wont control certain hi amp draw fans but you can fix that with a relay.
- Adjustable turn-on temperature from 150-240°F
- Turn-off temperature is preset at 10°F below turn-on temperature
Go to the Stewart Components web site and buy from them. They are worth every penny.
Cylinder bore from 170 degree coolant is a non factor. The difference in cylinder growth in 20 degrees is not enough to cause wear.
170 makes more power but takes a different tune up. If you are into emissions, catalytic converters and junk like that, run the 195. If you want horsepower, run the 170 and tune it for it. If you live in a temperate climate you may be able to use a 160. Or, if you only drive in warmer temps you can use it. I drive year around and in sub freezing weather so 170 is about as low as I can go and still get an effective heater.
The cooler thermostat will not make it run cooler. That's not how it works. Do like I suggested and read up on it.
I beg to differ, I have a 4 core aluminum 11/16" tube radiator and two fans that pull 4,000 cfm through them. That should cool it down to 170, I would think.
I agree. Maybe study up on what the thermostat actually does and what it really controls instead of trying to reinvent the wheel. I would run a 180 or 195. I plan on a 195 high flow in the big block I am putting together.
It will not. It's a known fact the thermostat only controls the minimum operating temperature, not the maximum. The max temperature is controlled only by "the rest" of the cooling system. The thermostat has nothing to do "with that". That's why I said, study up on it. I wasn't being a smartass, either. It's factual information. Look it up. Read about it.
I am familiar with how thermostats work. Please check my post under your first post for the reason why I want to go with a 170. Basically, I heard that the hottest you want an engine to run is 200 degrees. I don't want to run my engine red line, I don't run my tires low on air, I always check my oil before starting it after time, and I like to check the rad to make sure it is full, or 2" under full, lol... I just don't like to run her that hot because of the heat in Tx. Now when it goes down, I will probably run a 180 therm because the fans will need to turn on at just over 195.
Well, I kinda disagree with you. On start up, the therm is closed so the engine, can, heat up. I understand what you are saying about the therm opening and cooling the engine, but with that much fire power, I will bet you a nickle I can get it down to 170 in the Tx heat. You on? If that is... I can find one. lol
Disagree all you want. You are incorrect. This has been batted around on this and other forums for years. The only difference the lower rated thermostat make is, it opens earlier. That's all.
If you insist. I will keep the 180, after all it is less work to keep it in there. I'll adjust the controller to 198 or so. But I have to ask... why do they make 160's if the temp won't go down that far?
Thanks Rusty
Wow, sub freezing all year? Where's that if I can ask...
I checked Stewart Components, and don't mind spending $30-$40 on a good thermostat, but I couldn't find one by them. Maybe I didn't look in the right place but it looked like they only have 9 on the entire site.
I would like to know where you got your 170 thermostat, what year engine you drive. I have searched a couple days for a 170 and can find tons of Chevy and Ford ones, but not Mopar for some reason. They make late model ones, but not the hot rod era.
