[WANTED] 1963 Engine Manifold Stud, Nut and "D" Washer Kit
Narek H
Los angeles
Rating - 0%
0   0   0
Hi all,
I have a 1963 Valiant 225 slant six and I need a set of 'Engine Manifold Stud, Nut and "D" Washer Kit'. Below is a pic as an example.
Any studs will do, use brass nuts (wont seize onto steel studs) or stainless and anti-seize and get the correct center and outboard convex washers. Youll only need to look for the triangle and convex washers. Im sure someone has a set here.
Seize is an interesting spelling as it doesnt follow the rule of "I before E ...except as an "ay" as in neighbor and weigh".....? So is it really pronounced s'ay'ze?
And with the exception of my last name. Riveiro
Send me a PM. I know I have enough to make up a set. Washers will be used, Studs and nuts new. Have to dig them out. Can't do that till later today or tommorrow.
