1965 dart strut rod dimensions
Lukedecker98
New Member
Roselle IL
I have a 1965 dodge dart with a slant six 225 in it. I am currently rebuilding the front suspension. I am going to machine new strut rods for the car but mine have been cut and welded back together. I cannont get accurate measurements on the strut rods. i was wondering if anyone had these dimensions or knew where i could find them. I really only need the lengths. Any help would be appreciated. Thanks in advance!
One guy here sells adjustable strut rods. He must know dimensions and might state in his posts. You probably want slightly shorter than factory, to pull the lower ball joint forward. With radial tires one needs more caster, hence the adjustable rods. Otherwise, many install offset upper bushings to increase caster.
