1966 Barracuda 273 V8 with 10" inch manual rear brakes
fbscuda
Fresno, Ca. 93730
Unable to find all the hardware to replace the rear brakes. Parts Geek had the cables for the 10-inch brakes. The issue is the brake adjuster on the 10-inch is different than the 9-inch.
Does anyone know where to find the parts for the 10-inch? Very frustrated at this point, did not want to change the rear to disc, but may have to make the move.
Yep, a wanted add post will most likely get you a member that has it, if not I seen a rear disk breather set up bran new in the for sale adds
Funny how all the parts stores forgot early A bodies could come with 10" drum brakes. Look under coronet for 10". They are basically the same.
The last time I did drum brake repairs on the front, I found that I had to use the ones listed for coronet to get the correct hardware and adjuster kits. ( have KH disc's there now)
Front disc brakes is the next project.
