alaskadartgt
Member
so i have pretty much decided to go with the scarebird front disk brake conversion.
and i have also decided to stick with manual brakes. do i have to change my
brake master cly. ? their instruction sheet says to go to 73-75 dart master.
i emailed them asking basically why and if it was because the 66 original is a single res.
and the newer one is a double res. they simply said the single would work, but instruction sheet states "for best performance" use 73-75 disk brake master. any
help would be appreciated. thanks
also not to sound like a total idiot..... how do i "thanks" someone on here?
