1966 Inland Shifter Lower Boot
tone
North Carolina
Question for anyone who might know - my 66 Barracuda is in paint shop purgatory so I'm working through everything else not related to the body and have a question about the inland shifter linkages. The car is a 1966 with 4 sp console (Formula S) and when I pulled the inland shifter and the shift mechanism, there was no lower boot. I see that you can get reproduction boots, but my question is did the car originally come with one? I've cleaned up the mechanism, replaced the reverse lockout cable, replaced a few clips - but before I wrap it back up and put it on the shelf, if it came with a boot, I might as well get one and put it on (seems like it would at least help keep grime/road dirt/tar out of the mechanism and help hold grease better). Thanks in advance!
B-body inland shifters came with a lower boot.
I don't know why you call it marine??
Yeah, not sure why I keep using marine either. So the boot, maybe only a b-body thing?
Thought I'd show you how to install it, as it's not as easy as pictures make it look! Guess I should be use to FABO by now, where nobody thanks anybody.
As for "in an A body" Fisherpete confirmed that...
Maybe this will help :thumbsup:
