[FOR SALE] 1966 Plymouth Barracuda part out ×3
How much for the grill emblem to and how bad is the headlight trim
Here you go. I was wrong, 1 of them was in good shape no dents.
Just a heads up that looks like a 1966 Valiant headlight ring, they are different than Barracuda, Barracuda is narrower than Valiant since the grille is thicker...looks nice though
Good eye mine was wrecked on the ds so I don’t have anything good on that side so it will definitely be an improvement thanks for the info
I need a automatic steering column, column shift with all the linkages and brackets to the transmission.
The column shift car was missing the drive train. So all I have is the column but couldn't get the collar off the steering box so had to cut the shaft. I have a 3 on tree car I could pull the shaft from to make the column good again.
I need a set of motor mount brackets. Do you have a set and how much are you asking plus shipping to Los Angeles, CA 90041? Thank you
