1967 Cuda Horn ring removal???
peter36
New Member
Anola Mb
Hi all, how do I remove the horn ring on my 67 cuda so I can remove the steering wheel??? I am stumped! Thanks
Peter
just did a 66 belvedere, there is a c clip thing on top of the ring that holds it on the shaft.
There are three screws on a dart horn ring that hold it on. Just remove those 3 with the phillips head....
Just worked on a 69 Dart today...
Rotate the center cover about 30 degrees counterclockwise and lift off. Screws under that.
