1967 Dodge Dart Items Needed
ekb16hatch
Newbie
Indianapolis, Indiana
Rating - 0%
0   0   0
I am fairly new to the muscle car scene but things I need right off the top of my head are:
1. Both rear window crank handles.
2. Radio.
3. Antenna with cable.
4. Both rear taillight lenses.
5. Both rear reverse light lenses.
6. Trunk liner.
7. Glove box (not door actual box).
8. Guages and cluster (that actually work)
9. Metal tip end for passenger side sun visor or dark blue sun visor.
10. Windshield washer pump/ reservoir assembly.
11. All window and door seals/molding.
Thanks
Eric
2. Radio.
6. Trunk liner.
Thanks
Eric
.....I have a antenna..Cable cut unfortunately...a pair of visers blue not dark Cheap....I may have a reverse lens. Let me know.
I have a nice pair of reverse lenses, and a pair complete tailight assemblies if that helps.
Pm'd everyone. Thanks all! A68Dart360 I'm not sure if it will fit or not...does anyone have any feedback on this issue? I would greatly appreciate it. Also I no longer need an antenna...found one on ebay.
For all rubber parts for you dart go to "Softseal weatherstrip" first then on to "Year one" they have them all. Year one is more expensive.
Sheetmetal parts, Dessert Valley auto in Arizona they will have it.
Engine parts, Mancinni racing has it all, better than Jegs or Summit selection.
floor pans, Sherman auto sheetmetal, quality and reasonable. entier car panels.
electrical mostly from Year one again.
I have alot of hard parts/electrical/engine/trans when your ready for V-8 converson. thanks, Arnold
:banghead:I DESPERATELY NEED either a 318 or 340 complete engine in good condition....I spun a bearing in mine on Sunday and the other engine I was going to buy didnt work out. I could really use some help or guidance for my issue at hand. Thanks
Now that the heat is gone I'm pulling the stroked 408 cu in Magnum out and starting on installing the new 440 cu in. So the question is where to store both smallblocks? both have lumpy cams but run on pump gas.
2. Radio.
6. Trunk liner.
Thanks
Eric
I have alot of these 67 parts if you are sill looking,let me know.... scott
340man...I am still looking for
Trunk liner
Radio and heater bezels.
Just let me know thank you
I've got 67 correct window handles. They have some pitting in the chrome.
I have a good washer bottle with electric pump. I've got sunvisor tips.
I may have the cardboard glovebox liner also. pm me if interested.
Good hunting
