1967 Power steering help
mattydean
arizona
HELP the power steering is hitting the k member. What am I doing wrong. I have a Magnum Motor 360 with the 1970 later water pump. Do I have wrong pump or wrong brackets. Thanks for any help
That is the correct oval neck pump assembly for a 67 small block. I've never seen it mounted on a later 360 with aluminum water pump though. Those used a different pump/brackets/pulley.
I'm pretty sure I have the saginaw pump you need if you want to work a trade.
