1967 Valiant / Dart interchangeable quarter panels?
Garry in AZ
Building a 9 second Valiant
Mesa, AZ
Does the Dart use the same quarter panel sheetmetal as the Valiant? I can find replacement quarters and skins for a Dart, (AMD number 710-2067-L) but not for a Valiant. Is there a difference, and if so what is it?
Completely different, you have to use a Duster quarter as long as all you need is below the body line.
Found my answer... in case anyone else was wondering, they are not the same. The body lines, and wheel opening shape is quite different.
Thanks HemiSSDart... But no, I need everything from the door opening to behind the wheel well, at least to about 3" above the wheel well. The Duster panels won't work. Looks like I have some fab work ahead of me.
I never realized until I bought my 68 Valiant
They seem to be somewhat rare. And not many parts are made for them unless they fit other A Bodies.
If the rust isn't beyond the wheel opening and behind, you can use a 4 door quarter. And if it is, you can use the rear door skin. Not the best solution but until someone makes a Valiant quarter that's what we're stuck with.
