Asktoro
Ok, I'm tired of this car and can't work on it in the storage there's not enough room. Come and get it $4,000 and I'm only offering it for this for the duration of the winter. I'm taking a $700 hit of what I bought it for, and the reason for this is I tried parting it out but like I said, not enough freaking room. :wack: One of the members wants the headers so it will either come with or without headers, I tried to remove them but a bolt is making it impossible to because of the drag race config I have to put two nuts on the bolt to pull it so the header will slide out... but then radiator fluid spewed all over when I took one out... Go me (I never knew it would drain out like that...) So far I took the carb, manifold and fuel thing off, along with a few minor parts. The body and motor/trans alone should at least get me $4,000... :banghead: Anyways its hemmoraging fluids and...... yeah. =/ help me out, im cutting my losses and in a bind. (all the parts that I took off will go with it... If you just want the guts I'm willing to sell the engine/trans/drive line -- everything machinical for $3,000 and will help with removing parts.)
