1968 Dart with 273 v8. Car runs cool,gauge nearly always reads to the left,but I noticed today when checking coolant levels that even when the car has been driven a half hour and is up to temp there is no pressure in the upper hose and the cap can be removed with no pressure. The radiator cap is brand new,16lb which is correct for ac cars. Coolant is green and clear. I did notice a 4" string of orange silicone rubber floating in the top of the tank...but nothing else out of the ordinary and again the car never overheats. No coolant leaks on the ground anywhere.
So where does your darts temp gauge rest at when it's driving at normal temperature? Is there pressure in the top of your radiator hose when the car is up to temperature? Temperature out was about 75° today
