1968 Dart progress
Sorry, I should have been more clear. The brake hose/line from the rear axle to the body, SS springs hang down lower and will break it.
I didnt know they made different sizes? If so do u have a part number or a link?
I don't have a part number, sorry. If I remember right cars like the Plymouth Fury or Dodge Polara might have used a longer brake hose.
USCG, if you wavent put your rear brake line on yet, you will know immediately if it is gonna be too short.
The stock rear soft brake hose fit fine under my car with SS springs.
21 circut EZ wiring harness arrived today. Very nice set up as all wires a labled along with fuse box.
I installed the stainless front brake lines from "The Right Stuff". They fit and look great.
[ame="http://www.flickr.com/photos/tobysoldblue/5358809194/"]026 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm6.static.flickr.com/5008/5358809194_82f4ecdec3_m.jpg@@AMEPARAM@@5358809194@@AMEPARAM@@82f4ecdec3[/ame]
[ame="http://www.flickr.com/photos/tobysoldblue/5358808748/"]024 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm6.static.flickr.com/5125/5358808748_548eb306a5_m.jpg@@AMEPARAM@@5358808748@@AMEPARAM@@548eb306a5[/ame]
[ame="http://www.flickr.com/photos/tobysoldblue/5358193823/"]021 | Flickr - Photo Sharing!@@AMEPARAM@@http://farm6.static.flickr.com/5125/5358193823_43ac605470_m.jpg@@AMEPARAM@@5358193823@@AMEPARAM@@43ac605470[/ame]
Tobysoldblue did some port work on my large valve 360 heads last night. :cheers:
In the next few weeks.Im technically working 3 jobs at the moment,so progress is slow.I hope to have this thing roadworthy by march,hopefully.
Ok Toby is finishing up on porting the heads and intake... I gotta say this should be a strong 360 for a fun driver. I also bought some 68 buckets with matching rears, next week I will get the dynamat, carpet, and a few missing rubber for her... not long now fellas.
Today I decided to attempt to dye my rear bench seats from Green to Black. I gotta say they turned out great. The only small problem I see is that my front seats are more of a flat black vice the glossy black I dyed my rears. It's hardly noticeable. I'm thinking my solution is to just put leather conditioner on the front to make the glossy.
Looking good Jason.What type of wiring harness is that?I just ordered a Ron Francis harness and they said it was an easy plug and play.We,ll see.Say hi to Toby for me.Thanks.
Its a 12 circuit EZ wiring harness... I have to give all the thanks to Toby and the shop he works at in NC called "Kevin 4 wheel" They do a bad *** job at retso projects. The new harness replaced every single old wire in the car. They wired in a trunk light, master power on/off switch, and outside terminals for charging. The car has shaved doors, trunk, and fuel fill so they wired in remote door pops and trunk pops, I also have manual cables for driver side door and trunk. This week they should finish up the wiring and start the car for the 1st time. after the wiring is complete Toby will spray the rust encapsulator through the entire interior of the car and lay down sound and vibration deadener through out. Nest will be the carpet and headliner and seats followed up by the new dash bezels and stereo system (fiberglass 5.25" kick panels) with 6x9 in rear. all this should be complete by May.
i hope to pick up the car in June just in time to shred the tires is Toby and the gang hasn't already.
Jason
