hcallaway
Finally received the taillight bezels and more importantly the C gaskets that were holding me back.
When you had it in the air did you by chance use a 2x4 to put resistance on a wheel and see if the noise came or went?Definitely a rotating noise. Pinion or universal joints. Load takes away the sound. It will come apart this weekend
That's funny. My builder reused my trac loc spider gears rather than put new gears I supplied because he said there was no reason to replace them.It was the rear spider gears. So I took parts from the original rear & made it work
If the temp rise steadily while driving at more than 35 mph and not stopping then you have a water flow issue.I ran it for about 30-40 minutes. The temperature gauge slowly creeped up. Drove home when it went to the night side. It still was in the OK range. I ordered a fan spacer to see if that will have an effect
That will have an effectRadiator accepted another 1/2 gallon of antifreeze. Seemed to run in the normal range
I have been trying to get my wife to go for years.Wife after 40 plus years actually attended one. Her comment was; they were pretty nice people.
