Nico O'Hara
Active Member
Hello. Is there any way I can turn my back bench seat into a folding so I can route my upright bass from the trunk.
That can be cut out.?I'm sure it can be done but there is bracing behind the seat that would/ might be in the way
How much less stable?It is attached by two pieces of metal that fold over through the hoops attached to the seat. You have to remove the bottom seat first, then unfold the metal tabs, then lift the the seat off two hooks on the top. Like said above, there is an "X" brace on the back that would have to be cut out but then the car will be less stable...
I don't know, the only time I have seen it done is for a racecar when they are adding a roll cage. Don't forget that these cars are unibody's, so every structural member is there for a reason to keep the body stiff. If it is just a driver with not much extra horsepower then I think it would be OK, I was a design engineer in my working life...How much less stable?
I have a 7/8ths upright bass. It stands at about 6’1”There's plenty of room for the neck of the bass to go right through without cutting a thing. No way would I consider cutting.
Oh okay thank you. Considering everyone else’s post I’ll see what I can do about making it foldable and then see about if I really need to cut or not.I don't know, the only time I have seen it done is for a racecar when they are adding a roll cage. Don't forget that these cars are unibody's, so every structural member is there for a reason to keep the body stiff. If it is just a driver with not much extra horsepower then I think it would be OK, I was a design engineer in my working life...
I'm REAL familiar with them. I played both 4/4 cello and 4/4 bass in grammar and high school. It'll fit if you get the back seat to fold down.I have a 7/8ths upright bass. It stands at about 6’1”
Oh okay. Full size basses are pretty rare so that’s interesting.I'm REAL familiar with them. I played both 4/4 cello and 4/4 bass in grammar and high school. It'll fit if you get the back seat to fold down.
Well, this WAS from about 1974 to 1981.Oh okay. Full size basses are pretty rare so that’s interesting.
Sorry, I’m not trying to be difficult I believe you. Bass size standards have certainly changed over the years. Full size was usually for people over 6’4”. I’m 6’1” so 7/8ths is good for me.Well, this WAS from about 1974 to 1981.
This is brilliant.Have an upholstry shop install a fold down pass thru in the center of the seat . Like theg use for skiis on modern cars .
I wanna keep the cost relatively low and also I love the retro bench seats.Put buckets in it? Can you get a 2 door bench to fit?
