Welcome aboard.
The best rebuild kit for HP? Humm, I like to go to summit racing and go to there budget rebuild kits but swap out the standard piston for the one of choice. They adjust the price difference. For the rebuild kit, you'll need to have the following info on hand;
Bore size, which should be determined after the machinest works on it.
OH, by the way, don't overbore the engine if you do not have to. Thicker cylinder walls are stiffer and last longer. The extra .030 is nothing in HP.
And the crank as well. Strip it all down and give the machinest the block to clean and inspect as well as the crank. Once he's done, then you can order a kit.
Voo Doo cams are reaaalllly nice units.
