1970 dart swinger tail stripe, help needed
Mopar Body and Trim
  1. K.O. SWINGER
    K.O. SWINGER Meeting in the alley since 1976
    1,783
    1158
    Nov 18, 2010
    oregon
    Local Time:
    8:08 PM
    So I already crapped my first attempt of putting the bee's tail on my 70 340 swinger would somebody tell me how they accomplished it without flaws. Please.
  2. str12-340
    str12-340 FABO Gold Member FABO Gold Member
    1,764
    1034
    Dec 26, 2012
    Vashon, WA
    Local Time:
    6:08 PM
    What happened, what failed?
    • Agree Agree x 1
    • plymouth67
      plymouth67 It be a lot cooler if you did...
      1,518
      1949
      Sep 13, 2010
      illinios
      Local Time:
      8:08 PM
      Yes..more details...I just did one not long ago..wasn't real bad.
      • Like Like x 2
      • sabre67
        sabre67 FABO Gold Member FABO Gold Member
        972
        228
        Jan 9, 2015
        British Columbia,Canada
        Local Time:
        6:08 PM
        :popcorn:
      • Dartswinger70
        Dartswinger70 Well-Known Member
        1,696
        692
        Sep 20, 2005
        Southeastern Pa.
        Local Time:
        9:08 PM
        They are waterslide right? the sides line up around the quarter lights and I believe the trunk isn't exactly "straight" more like a "boomerang" because of how the body and trunk lid is. I haven't done one but will when I get mine in paint. This is just what I know from research. This is in terms of the kits out there. if painting one on I would assume the same holds true ,you wouldn't mask it exactly straight it wont look right.
        • Like Like x 1
        • plymouth67
          1,518
          1949
          Sep 13, 2010
          illinios
          Local Time:
          8:08 PM
          The one I put on from Phoenix graphics is "boomarang" across the trunk lid. If you were to paint it on you would do the same thing. The shape follows the shape of the rear of the trunk lid.
          • Like Like x 3
          • 1971 CY Dodge Dart
            1971 CY Dodge Dart Dart Swinger FABO Gold Member
            546
            306
            Sep 12, 2020
            Connecticut
            Local Time:
            9:08 PM
            Mines painted on. Impossible to screw up a decal. Disregard the reflections in my stripe from the picture also. Everything is perfect with them. 98866311-2718-466D-ADD0-1AFB5A136C03.jpeg
            • Like Like x 1
            • Disagree Disagree x 1
            • str12-340
              1,764
              1034
              Dec 26, 2012
              Vashon, WA
              Local Time:
              6:08 PM
              You will love this, because the trunk lid has a faint bend in the center, and the designers wanted the stripe to look like it was straight across when viewed from the back of the car, they put that shallow bend in the stripe. Give it a try, stand behind the car and take a look and... damned if it doesn't look straight. Clever fellows, those factory guys!!!
              • Like Like x 2
              • Dicer
                Dicer Back Bone beats Wish Bone all the time. FABO Gold Member
                1,313
                1866
                Jan 12, 2016
                Land of Lincoln
                Local Time:
                8:08 PM
                @K.O. SWINGER
                Wash the ass end of the car, mild soap and warm water, you want to remove the wax/cleaner on the painted surfaces. You would want the water to pool on the trunk lid instead of beading and shedding off normally as if it was wax. The car should be cool to the touch, get your spray bottle set up, faucet water with just a drop of dish soap, you are not blowing bubbles....
                Lay the stripes out flat and give it a day for them to relax. Remove the rear park lenses and cleaned the recessed area and in the trunk area around the hole.
                The fender stripes go on first and run parallel with the fender extensions and ALSO the park lens hole is centered in the stripe. The top on the stripe just touches the rubber trunk weather stripping.
                Water bottle, and spray and spray the underside of the stripe, you cannot over spray here, carefully position the stripe as stated above. Damp sponge squeeze some of the water off. Make a cut like this >----< where your holes are and gently tuck the flaps into the trunk area. Repeat for the other side, the hard part is done. You have to make a choice here... cut the stripe where it meets the rear valance and tuck it in or not.
                The big easy, spray the trunk lid and underside for the stripe, gently position the stripe using the already there fender strip for aliment and center the stripe by looking how much you have hanging over the edge of the trunk. When done open trunk lid water spray and take the stripe and work it around the underside of the lid. Use sponge ever so gently if you have bubbles they will dry out or take a needle pop it. Let sit out in the sun and stand back and give it big smile...
                • Thanks! Thanks! x 1
                • K.O. SWINGER
                  1,783
                  1158
                  Nov 18, 2010
                  oregon
                  Local Time:
                  8:08 PM
                  Yes I tried to apply my first one and I had a dry spot creased it and Bam $100 down the drain thank you for your direction. Brian
                • K.O. SWINGER
                  1,783
                  1158
                  Nov 18, 2010
                  oregon
                  Local Time:
                  8:08 PM
                  I'm not worried about placement my car had the factory stripe and I have good reference pics I just had problems applying the first one and when I talked to a professional he said he would apply it dry so I was looking for some more opinions thank you for your responses.
                • str12-340
                  1,764
                  1034
                  Dec 26, 2012
                  Vashon, WA
                  Local Time:
                  6:08 PM
                  if you get some small bubbles, don't sweat it. First good sunny day leave it out in the sun and they will come out through the stripe. I had pro do my first set and it had 10 bubbles under the stripe - I freaked. He told me not to worry, be patient. I took it to a show 2 weeks later, with the bubbles, and it was sunny and hot. By noon they had all disappeared... go figure
                  • Like Like x 1
                  • Agree Agree x 1
                  • dadsbee
                    dadsbee FABO Gold Member FABO Gold Member
                    778
                    1580
                    Nov 25, 2020
                    Penetang, Ontario
                    Local Time:
                    9:08 PM
                    No matter how tempting.. DO NOT poke the bubbles with a needle. They will start to show as dark spots very shortly afterwards as they collect dirt and start to show the body colour through the stripe. Some of my small ones took a full month to finally disappear, but as noted above by str12 they will go away.
                    My paint guy stated something similar to your guy... "I just put them down dry" and that's when I immediately decided to do it myself.
                    Ass end of car cleaned with dish soap and water, then endlessly wiped down with Naptha (Coleman stove fuel) to be spotless. Same deal on the aluminum sheet I had the decals laid out on before install.
                    Here's the install of the trunk strip on my Bee. Not sure which I like the most showing the install or the fact that my Wife of 39 years is right there helping install it to the car we were married in in '82! :thumbsup:
                    • Like Like x 2
                    • K.O. SWINGER
                      1,783
                      1158
                      Nov 18, 2010
                      oregon
                      Local Time:
                      8:08 PM
                      I have heard to do your side stripes first but you started with your deck stripe?
                    • dadsbee
                      778
                      1580
                      Nov 25, 2020
                      Penetang, Ontario
                      Local Time:
                      9:08 PM
                      Makes more sense to me to do the deck stripe first and then line each quarter up to match, vs quarters first and then trying to line the deck up with two locations. Also note the tape location marks to line things up... allowing for the backing overwidth to do so. (my battery died before finished on this one and I didn't know it)
                      • Like Like x 1
                      • Scamp Rhonda
                        Scamp Rhonda Well-Known Member
                        634
                        568
                        Jan 18, 2017
                        Blaine MN
                        Local Time:
                        8:08 PM
                        I can't imagine how fast and how non perfect they must have been when they put them on from the factory, lol. I'd be willing to bet no two are the same. Nice job, beautiful car!
                        • dadsbee
                          778
                          1580
                          Nov 25, 2020
                          Penetang, Ontario
                          Local Time:
                          9:08 PM
                          Here's where my stripe install starts in my Bee restoration thread on FBBO. May give you some assurance that you can get'r done...
                          1969 Dodge Super Bee Coupe Restoration
                          It shows it done, but keep scrolling down and then it described all the steps it took to do so..
                          • Thanks! Thanks! x 2
                          • challengergary
                            challengergary Well-Known Member
                            2,184
                            102
                            Jul 9, 2007
                            Port Saint Lucie, FL
                            Local Time:
                            8:08 PM
                            Nope - always start installing in the middle of any stripe kit that way if you are a little out of whack you can compensate instead of carrying the error out over a longer area. Side stripes, install doors first. Bumblebee stripes, install deck lid first.
                            • Like Like x 1
                            • toolmanmike
                              toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                              58,119
                              45194
                              Jan 18, 2006
                              Iowa
                              Local Time:
                              8:08 PM
                              Yep. Saw the pics yesterday and was curious as to how mine was. A-OK
                              • Like Like x 1
                              • K.O. SWINGER
                                1,783
                                1158
                                Nov 18, 2010
                                oregon
                                Local Time:
                                8:08 PM
                                I bought my 340 swinger in 1978 and the stripe was in good shape overall, I would have to think the decal department would be pretty Kush on the assembly line you mess up too many and you'll be heading back to the grinder shop LOL
                                • Like Like x 1
                                • K.O. SWINGER
                                  1,783
                                  1158
                                  Nov 18, 2010
                                  oregon
                                  Local Time:
                                  8:08 PM
                                  Looks great!
