dustinmoran91
1970 duster with no title, you can buy and part out as it is pretty much a race car but not a track legal one. I was building it to go fast on the street and thats it. Has a narrowed 8.8 with 3.73 limited slip and disk brakes, 727 that i was told is good but not certain, has a 318 with factory flat tops, new bearings and rings, magnum heads, howards cam with .501 lift 221@.050 and 276 advertised 108 LSA and 104 intake centerline. Has a holley 650 on it and a mopar blue box. Had it running for about 10 minutes to do the cam break in but didnt get to finish. Needs a different intake because that one was leaking really bad and messing with the break in. Has an off brand holley black pump thats brand new. Has all new front end including brake rotors, calipers, pads, bushings, bearings, ball joints, tie rods, pitman arm, idler arm, radiator, hoses also has 29/10.5/15 slicks on the back. All aluminum floor and a competition engineering roll bar, also has new brake lines and fuel lines, new master cylinder. This thing is far from pretty or perfect but i just wanted to go fast so thats all i was worried about. Looking for $2000 just because i have that in parts probably. Make me an offer and ill take it. cant get pics to upload but can email them or text them whichever you like
